squeak from the front end
Old Jan 30, 2004 | 04:16 PM
face1028's Avatar
face1028
Default squeak from the front end
i am getting a squeak from the front passengers side suspension. I was wondering if there was some sort of grease fitting in the suspension like a bushing or something. Or if it was the spring or strut??
Old Jan 30, 2004 | 07:29 PM
tchamber's Avatar
tchamber
I have the same noise, so when I got new tires, I asked them to lube it all up, and they said it wasn't in the suspension, but that my gfx kit cracked underneath and made the noise.
Old Jan 30, 2004 | 08:12 PM
bmorrisj's Avatar
bmorrisj
is it suspension noise or is it engine noise...if its from an engine component i suggest checking out the smog pump...
Old Feb 15, 2004 | 12:21 AM
stang574's Avatar
stang574
Does the squeak seem most obvious when you go over bumps or when you turn the wheel?
Old Feb 15, 2004 | 12:50 AM
BCisme's Avatar
BCisme
</P>
</P>
i love your avatar!!!<IMG src=smileys/smiley4.gif border="0">i say that to ricers all the time..... my turbo civic co worker always says, got boost? i say no...you got torque? no i dont need it i got boost... if you dont need torque then why arent you fasrer than me? lol i showed him your avatar and he was like, "whatever man..."</P>
Old Feb 15, 2004 | 04:20 AM
Milky's Avatar
Milky
check your pulley maybe? If its that, replace it.
Old Feb 19, 2004 | 05:09 PM
Stl Wild's Avatar
Stl Wild
Default RE: squeak from the front end
If it is only when you go over bumps, or when you turn... Push down on the passenger side of your car, If it squeeks when you do that then it is probly your upper or lower steering arm bushing. It could also be your shock but that isn't very likely. If it has nothing to do with going go over bumps or turning, then sorry for wasting your time.
Old Feb 21, 2004 | 12:48 AM
86lxconvert's Avatar
86lxconvert
Noises are hard to find you have to keep listening and checking all possibilities in the area. Spray silicon on the bushings in the area . And see what happens
Old Mar 17, 2004 | 11:38 PM
Jay95GT's Avatar
Jay95GT
Been there! Had a squeak on the right side only when turning. Thought it was the ball joint. During replacment of ball joint, ended up being tierod end. Get a buddy to listen while you turn the wheel back and forth.good luck.
Old Mar 18, 2004 | 12:46 AM
Dan04COBRA's Avatar
Dan04COBRA
Old thread man!!!
flash_xx
Oct 16, 2015 07:23 AM
kevsgt
Oct 9, 2015 10:12 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
