too much under steer
Old Feb 4, 2006 | 11:47 AM
95gt302's Avatar
95gt302
Default too much under steer
I have a 95 gt and hav far far too much under steer. Im wonderin if anyone knows wut i can do to lessen it.
Old Feb 4, 2006 | 11:51 AM
03redGT's Avatar
03redGT
Default RE: too much under steer
understeer means your car doesnt turn enough right?
umm maybe your wheels dont have enough toe in. or maybe your allignment is off. are you getting wierd tire wear patterns?
Old Feb 4, 2006 | 12:18 PM
Tim37's Avatar
Tim37
it means the car pushes through a corner even thought the wheels are truned the car doesn't repond right. btw if ya haven't noticed mustangs handle like a ***. if you got out of some kind of import or some car that handled well and started driving a mustang that could be your problem.
Old Feb 4, 2006 | 01:43 PM
marx91's Avatar
marx91
i have '91 and the turning radius sux, they changed how far the wheels turn
b/c of the 16" wheels that they started putting on in 91
Old Feb 4, 2006 | 02:42 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
if you really have too much understeer, then something is way off.
Mustangs do handle like **** but understeer is not a problem I have ever seen. If anything they suffer from extreme oversteer.
Are you lowered? Had any suspension damage in the front? Is the "understeer" the same when you are turning left AND right or only in one direction.
Old Feb 5, 2006 | 12:15 AM
kartracer55's Avatar
kartracer55
Ok, from a racing standpoint...
you can jack up your front pressure a bit to get the tires hotter. Also, running a little bit of negative camber in the front will INCREASE your contact patch when turning but DECREASE it when going straight, so braking will change... longer stopping distance. Also, by doing this youll notice your inside edges will wear faster and they will be hotter, so if you have a pyrometer youc an look for a 10-15* increase in temp.
This is just what wed do on the track to account for these problems, there are a few other fixes as well. Keep in mind though, these changes can/will mean unsafe conditions on highway/street driving. I wouldnt do this if it is your daily driver
Jim
Old Feb 5, 2006 | 12:28 AM
domesticfan's Avatar
domesticfan
ORIGINAL: 95gt302
give it some gas while turning.
lincolnshibuya
Dec 8, 2020 01:49 PM
CS2007
Jun 25, 2019 09:45 PM
allenmaty
Sep 24, 2015 09:17 AM
stark777
Sep 21, 2015 12:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
