Vacume leak
Old Feb 2, 2004 | 08:32 PM
Ormist's Avatar
Ormist
Default Vacume leak
Could a vacume leak be the case of my heat not working?
Old Feb 3, 2004 | 01:29 PM
97FordGT's Avatar
97FordGT
Default Vacume leak
i am not sure if it could cause the heat to not work. i havent heard of that b4 but can u hear air sucking from somewhere or is your idle off.
Old Feb 3, 2004 | 01:33 PM
vfast's Avatar
vfast
I ♥ Acer
Default Vacume leak
only if it's in the heater contol area..
Old Feb 3, 2004 | 01:35 PM
hotrodman's Avatar
hotrodman
I ♥ Acer
Default Vacume leak
that model dont have a heater valve with vac..could be your cable for our flaps
Old Feb 17, 2004 | 06:47 PM
mmoto68's Avatar
mmoto68
Default RE: Vacume leak
I have a '95 GTS. The heater control switch runs off of engine vacuum.
The main vacuum supply runs off of the firewall. You can trace it from the Brake Booster. The supply goes from the engine to a junction on the driver's side firewall, one goes to the brake booster, the other goes to the heater control. Since it's a cheap vacuum line subject to engine heat, it's probably cracked. If you pull off your glove box door, you can see the other end of the hose at the vacuum switch for the heater.
You can also test the switch by getting a good vacuum source and plugging it into the switch.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
