Powder coating ...... ?
Old Feb 9, 2006 | 10:54 PM
Ninety5five0's Avatar
Ninety5five0
Default Powder coating ...... ?
While my motor is torn down to the block i was thinking of getting some parts powder coated. I'm not too sure how things would turn out cuz i've really never seen a 5.0 with powder coated or painted motor parts. Anyone have any pics ? I know a guy who does powder coating and does it for fairly cheap. Would painting the parts myself be a better idea ?
Old Feb 9, 2006 | 11:04 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Powder coating ...... ?
I assume you mean brackets, valve covers etc? I would powder coat if it were me, it's much tougher and is pretty much maintinance free.
Old Feb 9, 2006 | 11:35 PM
gt96stang's Avatar
gt96stang
ORIGINAL: Ninety5five0
Powder coating will hold up better, and if you know someone that'll do it cheap, then go for it.
Old Feb 10, 2006 | 11:49 AM
Chopper's Avatar
Chopper
Powder coat is the toughest low temp coating known to mankind.
Old Feb 10, 2006 | 12:07 PM
closer9's Avatar
closer9
Powder coat or POR-15. Powder coat is strong, but standard powders won't handle high temp. Most cure/flow out from 350-400 degrees. POR-15 you can brush on yourself, and it will look just about as good, and be nearly as tough. Plus, you can touch it up should you ever need to. POR-15 now offers engine kits for around $45 in many OEM engine colors (which most good powders should be able to do also), much cheaper than powder coating...
BTW, here's a piston I powder coated myself. Just a paperweight, but looks pretty cool, IMHO...
jwog666
Dec 27, 2021 08:09 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
b8checker
Oct 8, 2015 12:55 PM
Oct 1, 2015 09:29 AM
b8checker
Sep 30, 2015 07:11 AM
