HEADS????
Old Feb 12, 2006 | 11:15 AM
1BIGMOFO's Avatar
1BIGMOFO
Default HEADS????
WHATS THE BEST KIND OF HEADS?????????, I HAVE AN EDLEBROCK UPPER AND LOWER INTAKE, (PERFORMER II) , EDELBROCK 70MM THROTTLE BODY, ETC. I KNOW THEY MAKE THE PERFORMER II HEADS TO MATCH THE REST OF MY STUFF BUT I HERD THE TRICK FLOW TWISTED WEDGE HEADS WERE ALOT BETTER. WHAT DO YOU GUYS THINK?
Old Feb 12, 2006 | 11:49 AM
TBird232ci's Avatar
TBird232ci
Default RE: HEADS????
ANYTHING BETTER THAN STOCK WOULD WORK GREAT!!!!!!SOME EDELBROCKS TRICK FLOWS WORLD OR ANYTHING AFTERMARKET WOULD DO GOOD FOR A STREET CAR!!!!!
Old Feb 12, 2006 | 12:46 PM
marx91's Avatar
marx91
yeah trick flows are good heads, AFR'S are real good too
Old Feb 12, 2006 | 01:01 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: StrongStang50
Please turn off the caps lock it makes it really hard to read your post.
Old Feb 12, 2006 | 01:26 PM
1BIGMOFO's Avatar
1BIGMOFO
sorry about the caps, i dont know too many things about heads, how do i know what to get for roller rockers? or springs or cc's. how will i know exaxtly what to look for and where do i look? thanks for your help guys
Old Feb 12, 2006 | 02:30 PM
JD1969's Avatar
JD1969
Rockers will come in different ratios (1.6, 1.7 etc.) 1.6 is stock and 1.7's will give about .030 more lift at the valve. Any time you change the lift you should also check the piston to valve clearance or you risk smacking a piston with the valve. Springs are matched to the cam, the cam manufacture should be able to give a reccomendation as to what spring to use. CC's refer to the size of the combustion chamber in the head. Unless you are trying to raise the compression ratio I reccomend finding a head with the stock (or as close as possible) size chamber, a few cc's either way won't make too much of a differance.
Old Feb 12, 2006 | 02:40 PM
1BIGMOFO's Avatar
1BIGMOFO
thanks alot thats a big help. At the moment I have everything but heads, cam, and the block done, i have a completley seperate engine, out of an 86. ( because my 94 has a knock sensor and i want to go with a gear drive timing chain). I plan to go with a 347 stroker kit, should i wait till the block is done and get the "Right" size heads for that block? The whole car is done other than that and paint . I dont like to have to buy things twice. I would like to stay away from the bottle and a charger/ turbo.. I just like raw muscle. I found a shop in the bennington vermont area that i would like to do the work. but i want to do some research to make shure i do it all right the 1st time
Old Feb 12, 2006 | 05:25 PM
JD1969's Avatar
JD1969
Ehhh.... please don't put a gear drive on there. They are old crappy 1969'stechnology and they transfer harmonics through the engine. Look around at what the best engine builders are using and you will see that none of them use a gear drive. A good double roller chain is all you need. If you plan on a 347 then buy heads and a cam that are based on that amount of cubes.
Old Feb 13, 2006 | 07:23 PM
1BIGMOFO's Avatar
1BIGMOFO
OK Thanks alot, i think i will wait on the heads till the engine is done.. thanks alot for the advise!
Old Feb 14, 2006 | 12:38 PM
Tim37's Avatar
Tim37
put some yate's heads on it.
