Tests before charging...
Old Feb 15, 2006 | 06:26 AM
Does Not Exist's Avatar
Does Not Exist
Default Tests before charging...
All right so I'm going to try and buy a supercharger in the coming months for my Cobra with 6-8 lbs. of boost. I know I should run a compression test on the motor to see if the cylinders are good to go. I was wondering if there are any other tests I should run before jumping into the boost? Also My car has a little oil leak coming from the rear main, will supercharging make the leak any worse?
Thanks
Old Feb 15, 2006 | 08:43 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Tests before charging...
ORIGINAL: boostin95cobra
Thanks
No need for a comp test if the car runs fine. It won't make the rear main leak worse either. I have a 92 lx w/ 150k on it runnin' 14 lbs of boost. no issues!! Good luck!!
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
