Water Outlet Question..
Old Feb 17, 2006 | 07:52 PM
1BIGMOFO's Avatar
1BIGMOFO
Default Water Outlet Question..
I had a friend helping me throw a 160 degree thermostat in my 94 5.0 he broke my stock water outlet. I work part time at advance auto so i baught one for like 13 bucks. It is like 3 pounds heavier than the old one plus the hose will not fit in the side of it from the water pump.. The actual water pump is so close to it there is not enough room for the hose or a hose clamp to fit... Latham Ford wants $140.00 for a new one and they hafto special order it... any recomendations?
Old Feb 17, 2006 | 07:58 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Water Outlet Question..
I had one of those chrome jobs from 50 resto on mine, Worked fine. 25 bucks I think.
Oh and I wouldn't put a 160 in it. I'd go w/ a 180. The car may not run right because the engine temp is not warm enough.
Check the link below and read the feedback about the stats. It may help you decide.
https://mustangforums.com/m_1036826/tm.htm
Old Feb 17, 2006 | 08:25 PM
1BIGMOFO's Avatar
1BIGMOFO
thanks so much, ill order one right now!
Old Feb 17, 2006 | 09:10 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: StrongStang50
Oh have you tried a salvage yard by any chance? Lotta 50 motors out there.
Old Feb 17, 2006 | 09:13 PM
1BIGMOFO's Avatar
1BIGMOFO
i just ordered a ford racing one for 23 bucks and a mr gasket 180 degree t-stat. w/ shipping and all gaskets 40 bucks ill have it all wed or thurs! thanks for the advise
Old Feb 17, 2006 | 09:15 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Not a problem, glad to help. Hope it works out for ya!!
Old Feb 18, 2006 | 10:29 PM
dsum14's Avatar
dsum14
I also have the chrome one from 50resto.com it fits great, but make sure you tighten the bypass tube and nut on top of the outlet. I must have took it off and put it on 10 times before I figured out that was where it was leaking.
D
Old Feb 19, 2006 | 03:44 PM
1BIGMOFO's Avatar
1BIGMOFO
cool thanksalot. i will have the new one wed, or thurs... im itching to take the car for a rip bad
Old Feb 20, 2006 | 02:25 PM
Mustang#2's Avatar
Mustang#2
Ya they leak many time from the top nut I ended up using thread wrap for pipe fittings and it stoped. Mile had a slot cut in it and you had to use a flat blade screw driver to tighten it... Couldn't get it tight enought and had to use the tape
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
