Valve Spring Question
Old Feb 18, 2006 | 04:23 PM
89chatofive0's Avatar
89chatofive0
Default Valve Spring Question
Those anybody know, or is anybody out there using a B303 cam with factory springs. I ordeered a set of springs from summit, but if i can use the stock springs that came on the GT 40p heads I got I will return the springs i bought. 110.00 to much for a set of springs.
So anybody with spring experience, hit me back.
Old Feb 18, 2006 | 08:43 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Valve Spring Question
I don't reccomend using stock springs with any type of aftermarket cam. Stock springs are barley able to control a stock cam. You could go into valvle float if you use the stockers with the E cam
Old Feb 18, 2006 | 08:46 PM
grabbem88's Avatar
grabbem88
you think 110 bones it too much for springs?
oh make sure you have matching locators,and retainers.
Old Feb 18, 2006 | 09:13 PM
HMS's Avatar
HMS
Do what I just suggested to another stanger....use the crane kit. Look at the thread "E303 with stock heads" in general tech!!!!! Perfect match for the B & E cams.
Tivo304
Aug 28, 2023 12:19 PM
PullTab
Oct 30, 2015 08:46 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Sep 1, 2015 08:16 PM
