POWER WINDOW AND DEAD BATTERYS
LIKE A LOT OF YOU MY BATTERY HAS GONE STONE DEAD TWICE ON ME AND LIKE A LOT OF YOU WAITING TO HEAR WHAT THE PROBLEM IS FROM MY LOCAL DEALER. SOMETIMES ITS EASIER TO GET ANSWERS HERE SO HERES WHAT HAPPENED. THE CAR BY THE WAY IS A 06 GT WITH ABOUT 500 MILES ON IT. THE SECOND TIME MY BATTERY WENT DEAD AFTER I CHARGED IT I NOTICED THE DRIVERS WINDOW WOULD NOT GO UP THE LAST INCH AFTER DOOR WAS CLOSED. IF YOU SIT IN CAR AND PUT WINDOW ALL THE WAY UP AND OPEN DOOR IT WILL DROP DOWN THE INCH TO OPEN BUT STAYS THERE AFTER YOU CLOSE DOOR AGAIN. ALSO NOTICED AUTO UP WITH DOOR SWITCH ON BOTH DOORS WOULD NOT WORK. AFTER DISCONNECTING BATTERY AND HOOKING IT BACK UP AUTO UP WITH SWITCH ON PASSENGER DOOR WORKED FINE BUT STILL NO AUTO UP AND WINDOW STILL WONT CLOSE THE LAST INCH WHEN DOOR IS CLOSED ON DRIVERS SIDE UNLESS YOU USE THE SWITCH. I FEEL IT MUST BE SOME WAY THE DARN MEMORY WAS LOST AND THERE COULD BE SOME TRICK TO RESETTING IT. THANKS FOR ANY HELP.
The owners manual has a reprograming or resetting procedure. That should fix it.
Also, when you type in all caps on the internet it's like shouting and should only be used for emphasis or if your really pissed.
ORIGINAL: MICHAELPQLEMON
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
pottsi,
