GRRR...rear end noise X 2
Well I took the car in a couple of months ago for the clutch pack issue. Car was fixed or so I thought, but now it's doing it again. Was wondering if anyone else has had this problem. I saw a couple people had clutches and bearings replaced, but I know I only had the clutches done.
Makes me think it might be something else since it doesn't do it all the time. I tried to make it do it today, but no luck so it's not a constant problem. I'll check on the TC issue. It's an interesting thought. Also, the car has Eibach Pros. I'd swear I've heard a strange noise or two not when turning, but when unloading the rear then reapplying pressure (and no, not getting airborne, but crossing rougher pavement maybe quicker than I should). Guess we'll see.
RE: GRRR...rear end noise X 2
Just to let everyone know. Took the car in today and the tech immediately said the clutch packs were blown again. Looks like the original ones were bad and there were several sets of bad replacement parts as well. So if you're car is making a groaning type noise in tight turns it is a problem. I tried the TC and the tech thought there was no way that could ever be the case.
