Carbon Fiber shaft drive
#21
RE: Carbon Fiber shaft drive
it's big heavy terd. the lightweight shafts reduce rotating weight by at least 30lbs. that is huge! also i've seen more than one post regarding the factory shaft getting twisted up like a pretzel. usually from 6000rpm launches with slicks.
#22
With the previous 05+ units there really weren't many reports of twisted shafts but with the newer 2005 GT units their have been consistent issues with the two piece DS twisting under moderate power adders.
#23
ORIGINAL: Nichepi
Any how many of you have ACTUALLY HAD a CF unit?
I myself had used tested CF shafts since 99 on a 99 cobra, 01 cobra, 04 cobra and I'm waiting for our 06 unit.
In every instance the unit we had was lighter (aluminum ends) and better then any aluminum unit we got from FRPP or other competitors in the market.
Our CF unit with aluminum ends for our 01 cobra with a replaced solid axle weighed only 11lbs.
We saw night and day benefits immediately such as reduced vibrations (most the time most vibrations disappeared), quick rev matching, easier shifting, HP and trq gain through dyno numbers and so on. No rusting and these units tend to be internal balanced so theirs no external weights.
Granted the prices over all have been much more then aluminum units but I'd never on my worst day with a CF unit ever say I'd take an aluminum unit instead.
And under very few circumstances have I heard CF shafts coming part on a street or race stang. As examples I’ve wheels fly off and hit the shaft on the ground, slid off of tracks and I just didn’t see these units come “flying apartâ€.
I would ask chevykiller to show me some of his personal examples of these showqueen items on his mustang or vehicles to back up his claims through direct usage.
I give the benefit of the doubt to many whom start taking about CF units and not having one due to cost but I think many of the statements made above were false.
Now for a majority of the market I would say yes an Alum unit is the path you should take due to vehicle needs and budget. But just some of the points made above I have never seen. And I can say through years of direct usage I have never seen these problems.
Here is a pic of our 55. This car makes 1860 HP with 22 psi on an old whipple screwblower. This heavy beast runs 9.30's. Another one of our cars pictured is the 41' all steel *****'s. This car makes 1200 HP and runs consistent 9.40's. Both of these cars have aluminum driveshafts and we have never once broke one. We have 7 other street legal drag cars as well and every one of them is a below 10 sec car and has an aluminum drive shaft. If you think you're going to be pushing more torque and HP than any of these monsters, then yeah, maybe you should consider it, but if not, then don't waste your money.
Mark
More pics of these cars and some of our others at my wife's grand opening for her clothing store:
http://homepage.mac.com/chevykiller/PhotoAlbum5.html
[IMG]local://upfiles/24802/C5C140358AF4447CB1F0C7DF222E74F5.jpg[/IMG]
[IMG]local://upfiles/24802/8CAFF16B89F949ECB48A89730EF629B4.jpg[/IMG]
#24
I see you points and they are very good.
But if we take in account that same mentaility that no one would ever need one, we might as well say no one needs anything. Stock control arms are fine. Stock clutches are fine, stock everything is fine.
