Tires
Old May 27, 2006 | 09:46 PM
herbieUSMC's Avatar
herbieUSMC
Default Tires
Alright so I went to the track last night and did 3 runs, best being a 14.2. I just could not get traction on the stock tires with my new 4:10s! Spun almost all the way through 2nd. I still have the Pirellis 235/55/17 on there and i am shortly going to switch those out with BFG KDWs. My question is what is the widest tire that will fit on the stock rims? And also those of you that have the KDWs what sizes are you running? Thanks!
Old May 27, 2006 | 10:09 PM
CrazyAl's Avatar
CrazyAl
Default RE: Tires
Tires are going to be one of the most important things to get right on the strip.
First things first, what air pressure were you running? You can lower your pressure a bit to get a bigger contact patch and better traction.
This is just a top-of-the head guess, so check it out before committing, but you could probably run 255/45/17 on the stock wheels.
You might consider buying an extra pair of wheels--slap some drag radials on there for use on the strip.
Old May 27, 2006 | 10:21 PM
callahan's Avatar
callahan
Default RE: Tires
255/50-17 is the largest tire that will fit the stock 17X8 wheel and still have the same rolling diameter as the stock 235/55-17's.
Old May 28, 2006 | 09:57 PM
The Ghost's Avatar
The Ghost
Default RE: Tires
ORIGINAL: herbieUSMC
My exact same problem, I am glad you asked this Q because I am also going to go with the KDW2. But i want as slim as possible on the front. SO.....someone chime in with this as well. I have 255/50-17 as the largest. What's the smallest?
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
