Scratches on paintwork
Old Jun 5, 2006 | 04:35 AM
nickbrace's Avatar
nickbrace
Default Scratches on paintwork
Hey guys,
Been a while since I last posted. Had a question - I have a couple of light scratches on the drivers side door nearby to where you put key into lock.............are there any products that will do a good job of losing these scratches??
Old Jun 5, 2006 | 05:19 AM
vponymike6's Avatar
vponymike6
Default RE: Scratches on paintwork
well, on your door panel there should will be a paint code on the sticker with all of the specs on it. Go to the nearest ford dealer and order a bottle of touch up paint in this code. it will be the same as your car paint now
Old Jun 5, 2006 | 02:31 PM
LEJAY's Avatar
LEJAY
I ♥ Acer
There are scratch remover type waxes, scratch color filling waxes and good old fashioned rubbing / polishing compounds. You said they were "light", so I'd try the scratch remover first, or........................................
A combination of these could make your scratches disappear or at least be tolerable.
I ain't a big fan of "touch up" paint.
JMO
Old Jun 5, 2006 | 02:45 PM
Racefiend's Avatar
Racefiend
I agree with Lejay. It's awefully hard to get touch up paint to look right, especially on anything other than a chip. I use 3M Perfect-It II Rubbing Compound - Fine Cut for swirl marks and light scratches. It's a very light rubbing compound best used on an orbital. Works great.
Old Jun 5, 2006 | 02:57 PM
tdappleman's Avatar
tdappleman
I agree - don't use touch-up paint unless you absolutely have to. If the scratches are light and don't go through the clear or color coat then use a good polishing product. If you have an orbital buffer use it as the speed and motion enhance the capabilities of the polish. If you don't have one, try the new PowerBall from Mothers - fits into a drill and works really well. You can clean it and reuse it - works on multiple surfaces with multiple types of cleaners/polishers. When you're done with the polish make sure you put a good coat of wax on since the polishes typically do not contain any wax or sealant. Polish / light scratch removal recommendations: Meguiar's #9 Swirl Remover, Mother's polishes and the 3M Perfect-it II polish mentioned above.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
mustangchef
Sep 4, 2015 08:08 PM
CarGuyZM10
Aug 31, 2015 07:08 PM
DrunknRuckus
Aug 23, 2015 10:05 AM
James Watson
Aug 6, 2015 06:42 AM
