Two Questions (Headlights and Engine)
Well I do alot of night driving, and I have noticed that I couldn't see nearly far enough infront of me with the headlights and foglights on... So I aimed the headlights up about 3 inches about the foglight mark at 25 feet from the wall.. I can actualy see infront of me now... Did anyone else have to adjust the headlights from the factory? They were even, just too low it seemed...
About the engine.. I see that the redline on the Tach is 6000, but I read that the rev limiter is at 6250... Is this the redline of the engine and it wont hurt it taking it that high? Reason I ask is because when I'm going fast, I like to try to look at the road and this thing revs fast when it gets up there! And I don't want to hit the rev limiter and worry that I damaged my valves or something afterwards...
Thanks
Thanks
RE: Two Questions (Headlights and Engine)
As for the headlights, I have not really had that problem. The redline is factory set at 6250. I have mine reset, by my custom dynotuner, at 6700 and I shift at 6500 at the track. You will have no worries. They pulled mine to 7000 on the dyno more than once and all is well.
Yea, it was definitely unsafe... someone should tell them about it... I just did mine last night, and they are still maybe a tad too low... I heard that you should clearly be able to see a man walking in the shoulder of a highway a football field away on low beams.. something like that... The top of my beams were probably even with the fog lights... I went about 2 - 3 inches above those at a wall like 25 feet away...
inyadreems
08-21-2015 09:10 AM
HIS S-197
08-10-2015 05:47 PM
