Transmission Shake(auto)?
My "new" '99 Automatic with 4.6 has a transmission shake, especially in OD at low speeds. Feels like it is running on 7 cylinders. I am going to check the TSB's but thought this may be very common and somebody will know what it is and the fix, hopefully! I was told that the tranny needs new fluid and there is an additive that is supposed to remedy this possible converter shake/shimmy. Ring a bell with anyne? Thanks, Mark
RE: Transmission Shake(auto)?
It's the torque converter. Possibly can be fixed with just a fluid and filter change, however I had changed the fluid with the same problems and the shake was still there. Then you have to replace the torque converter to remidity the problem.
My Dad ( God rest his soul .. my best friend ) anyway .. he had / my Mom has it now..
a 97 Windstar .. it sounds just like YOUR problem.. but you won't like my answer.. it needed a trans overhaul.. sorry.. as far as adding.. snake oil/ additive.. you are wasting your money and may cause more problems...
JMO
best of luck
Rex
JMO
best of luck
Rex
Thanks. I did a google search and came up with the problem and supposed answer. Use the correct Dexron 5 fluid and an additive for the problem. As stated it is the torque converter and if needed then that is what I will have to get! Thanks and I will check out the 4.6 forum for older cars, didn't see it, sorry! Mark
