Feedback on Saleen supercharger
I have a 2006 Mustang Gt . I am looking to increase the HP. I am considering a Saleen Supercharger . If you have put one on your GT I would like your feedback.
Best price you found for supercharger ?
If professional install how much ?
If you dyno tested did you get + 400 hp ?
Any learnings or issues ?
Is there a better altenative to boost HP to around 400 hp ?
I am just looking to have some fun with the car on weekends nothing serious .
Do I need to tune the suspension ?
RE: Feedback on Saleen supercharger
Saleen makes a great product. Kenne Bell makes another good one. Suspension tuning is a fucntion of what type of driving you want to do. It would not be a bad idea to look into the "Procharger" by ATI, the make a kit for the new motor that will put you well into the 400+ HP range with little modification.
good luck to you
good luck to you
To saleen and eventually FRPP/whipple look to be the two best.
From what I hear, on the saleen, larger injectors, colder plugs, and an upgraded fuel pump are neccesities.
To me, if I was going to do it, I would do that as well as match it with a C&L racer and a smaller pulley to get to the 450-475 RWHP range.
I havent heard anything good about the stock saleen tune. So the above and a custom tune may be your best bet. OR, wait till the packaged setup from FRPP comes out and see what that looks like.
ORIGINAL: wvabear58
If professional install how much ? with dyno tune & other parts $7000 (includes the $5100).
If you dyno tested did you get + 400 hp ? 373 w/4psi boost but I have an automatic transmission
Any learnings or issues ? Aftermarket billet throttle bodies won't fit a Saleen unless you fab up a 1" spacer.
I highly recommend HPP in Lewisville TX to do your install!
My car drives normal until you punch it and Katy bar the door!!!
Hope this helps.
Mike
If you are interested in buying the Saleen Supercharger, please read this link:
https://mustangforums.com/m_1570456/...tm.htm#1570456
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
09-28-2015 10:54 PM
