Which way to go now?
#33
RE: Which way to go now?
I have the Mezeire and there is definitely more power available to the wheels as a result. I haven't run it all the way up the RPM dial yet, but I'm sure the difference can be felt up there, too. You all have to remember that with the mechanical pump, you probably run into some cavatation issues when the engine is wound out. Those water passages can only flow so much water. Why have a mechanical pump fighting against the pressure when it's unnecessary?
