Do you need cams?
Old Jul 24, 2006 | 01:29 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
Default RE: Do you need cams?
ORIGINAL: blowngt
NO...
The cams in these cars are not a weak link and I did more research than I wanted to cause the cam issue was a big one for me. After it was all said and done, I personally believe that the offerred cams for our cars really do nothing more than give you that muscle sound. I honestly believe that in a year or two, there will be some serious custom cams for our cars but I just don't see that right now. How well will the stock cams hold? Well, JDM has them on a 900hp turbo car spinning 7600 rpm with no problems. Livernoise has them on their 770 hp car spinning at 7400 rpm. Justin Burcham has them on his car spinning almost 7600 rpm, powerhouse has them on their 660 hp car spinning at over 7000 rpm. Get the point...lol
If they are so bad, then ask yourself why all the top cars out are running on the stock cams? The reason is, they are good. The trick is to upgrade everything AROUND them. The cams will hold at high spin just fine as long as you take care of everything else.
Now let's look at cost cause if you thought you just buy the $650 cams and drop them in, then you thought wrong. The only real reason to want cams is to be able to spin your car up but in order to do that, you're going to need valves, springs, retainers, rockers, seats, ports, etc. etc etc. So that $650 quickly turned to over $2500.
Now if you just want that old school rumble, then wanting cams might be your bag, but you certainly don't 'need' them. In case you're wondering, the GT500 utilizes the exact same cams that are in the GT now.
didn't know the GT500 was a 3v. LOL. maybe you mean the lift/duration specs are the same?
contrary to popular belief, heads/cam WILL get this car into a pretty good HP range. according to MMFF, a stock s197 GT made 330 TO THE GROUND with just stage 1 heads and stage 2 cams. i think thats pretty good. i think the main reason most people do cams is not for the high RPM potential; but a) the sound and b) the bit of extra power up top. they are not exactly useless; but i could stand to see some better options than there are out there now.
and btw, listen to this.
http://videos.streetfire.net/search/...3e14ee561a.htm
Old Jul 24, 2006 | 03:50 PM
viking396's Avatar
viking396
Now that is what I'm talkin about! Hell I'll spend the money for the idle alone! WOOHOO!!!
[sm=happy046.gif][sm=alcoholic.gif][sm=burnout.gif][sm=gears.gif]
Old Jul 24, 2006 | 05:21 PM
td1320's Avatar
td1320
+1 /\ /\ /\
Old Jul 24, 2006 | 06:47 PM
blowngt's Avatar
blowngt
I ♥ Acer
As I have said all along, that's the reason guys are buying cams right now.
Old Jul 24, 2006 | 07:00 PM
slowpozer's Avatar
slowpozer
ORIGINAL: viking396
The stock cams vs aftermarket cams are more different than you think. A read on Comp Cams site will help out here.
http://www.compcams.com/information/...yID=-944523949
That's a claim. Why no before/after dyno numbers?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
