C&L Guys come in
RE: C&L Guys come in
ORIGINAL: mlcrycc
Just out of curiousity, did you all use the optional bracket off the valve cover, or not??
a lot of ppl didn't use them. . . but i did, and i had to customize it a bit, but its snug as anything
i made it to where i could use the factory valve cover bolt, i cut a chunk out of the side of the loop from the bracket to where it looked like a hook instead of a loop, then slid it around the gapping in the factory bolt, and screwed it back down in the valve cover, worked perfectly.
To be 100% sure Im not hearing dentonation(my rattle problem), I pulled a pulled a plug to make sure. The plug looked great, I have been driving with my tune for over a month now so there is plenty of time with the tune in place to have a decent reading. I was suprised that the plugs were 9/16th socket, and thank god these plugs are easier to get to unlike the earlier mod motors. I tightend the heat shields under the car a bit and that helped alot, but the slight rattle is still there just a wee bit. I'll just need to open up the exhaust more to hide these noises.
ORIGINAL: ski
Check the dust shield on the tranny's bell housing for 2 missing bolts. This can also cause noise.
ORIGINAL: 05 Ricky
Missing bolts? Did you have missing bolts, I didn't notice any missing.
ORIGINAL: ski
