BMR Rear LCAs
RE: BMR Rear LCAs
Thanks Scramblr, that is a good write up. I didn't think the axle would shift that much. I'll probably use the ratchet tie down method since it looks a little easier.
RE: BMR Rear LCAs
Had the CHE Poly to Poly LCA's w/ Relocation Kit installed (street use). Took off the Factory axle weights.
Dont forget to have your pinion angle checked after install. It should be set at -3 degrees under load.
Matt's 95 Stang
10-05-2015 07:16 AM
