Running lean?
Old Oct 23, 2006 | 12:13 AM
Bigbishjas's Avatar
Bigbishjas
Default Running lean?
I had a dyno on Saturday and my 06GT's air/fuel ratio was running at about 13.5 on the final pull...in the 4k to 6k range. Should I use my Predator to adjust my air/fuel in that category down a bit or up a bit? Im not sure if I was adjusting it correctly on Saturday. This ratio was taken from the exhaust so I was told it may run .75 high or so. For the S197s what is the ideal air/fuel ratio? I was thinking around 12 or so.
Old Oct 23, 2006 | 12:55 PM
Johnnie D's Avatar
Johnnie D
Default RE: Running lean?
not an expert here but i think the stangs like to be around 12.8 and if i am not mistaken when they read from the tailpipe your air/fuel is not as accurate...I was told that the tail reading would be a few tenths lower by the o2 sensor, meaning your 13.5 may actually be a 13.2 or so....but again I am not an expert here
Old Oct 23, 2006 | 04:15 PM
cekim's Avatar
cekim
ORIGINAL: Bigbishjas
13.5 is about where the computer will try to keep it when in "closed loop" mode (i.e. NOT Wide-Open-Throttle)...
So, at idle and when not floored, it should hover right around there... If you were indeed at WOT, then that is high...
Optimium HP generally comes around 12.5 but at high RPMs many tuners will push it below that for a margin of saftey...
Old Oct 24, 2006 | 12:14 PM
Bigbishjas's Avatar
Bigbishjas
ORIGINAL: cekim
Thanks for the help
Jb145700
Aug 21, 2022 06:37 AM
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
uedlose
Sep 10, 2015 03:30 PM
