getting rid of the cats affect the warranty???
RE: getting rid of the cats affect the warranty???
ORIGINAL: Bayouboy4.6
i am thinking of making some fake cats to put on.[sm=badbadbad.gif]
ORIGINAL: eleanor19
ok here is the deal. taking ur cats off and getting the mil eliminators will not hurt your car. technically it should only void the warranty with anyting pertaining to ur exhaust. with ford, if you for some reason blow your motor and dont have ur cats, even if the offroad mid-pipe is not the cause, will still try to blame ur offroad mid-pipe for the problem. so basically taking ur cats off should not "void" ur warranty, but beware of ford blaming anything on u not having cats.
http://forums.genvibe.com/zerothread?id=101
http://www.alternativeauto.com/water.../warranty.html
http://www.impalaclub.com/naisso/magmoss.htm
http://www.enjoythedrive.com/content/?id=8123
http://www.enjoythedrive.com/content/?ID=8124
http://www.ftc.gov/bcp/conline/pubs/...#Magnuson-Moss
Att. Andrew
There used to be converter bypass pipes available some years ago for "testing purposes only" that were forced off the market by the Fed. Modern converters are much more efficient than they used to be. A GT-500 moves a lot of exhaust through its converters and makes big power. Without them (even if you could easily gut them to pass a visual inspection) you will fail an emission test. You will need to reprogram your ECU because your exhaust back pressure will change affecting all kinds of fun stuff. The sound of your exhaust will be a bit louder but not as much as you might expect. Say goodbye to any warranty you have and also risk losing your registration until the vehicle is proved to be back in compliance. Still want to 86 your cats?
RB
RB
ORIGINAL: zcat
Eleanor19 - Is it as simple as turning the cats off with my Diablo? If not, how do I do it and what is a MIL elinator?
Roger that Musiccity - I will be correcting the lean condition 1st. If the cats come out, it will more than likely be because I drag them so easily and I believe they'll keep dragging till they're damaged. I've heard that the ceramic inside can break up causing blockage in the exhaust - that could be a little detrimental to engine life[:-]
ORIGINAL: MusiccityGT
Zcat, you can use the diablo to disable the rear o2 sensors. The MIL eliminators plug into the harness' in place of the o2 sensors and trick the ECC into thinking they are there, hence not throwing a check engine light. With the high flows you have, you will likely see very little gain. Not worth the trouble IMO. With your current lean condition during open loop, I would be leary of eliminating the rears to possibly allow a lean condition in closed loop.
ORIGINAL: zcat
so are you saying that the car will run lean?
Its simple I ran over a a rock in the road and it cracked my cat so I had to replace my stock pipe..
Also down here in FL, dealers really don't care about the cats as there is no inspection or emissions testing. So its a common mod
KingRando
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
09-24-2015 09:18 PM
