error code P0456
Old Nov 21, 2006 | 05:30 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
Default error code P0456
thats what my check engine light, i think its "evaporative emissions or something"
any ideas?
Old Nov 21, 2006 | 10:23 PM
06GT4RAD's Avatar
06GT4RAD
Default RE: error code P0456
I do not have the current codes but that code is normally related to a small EVAP System leak Usually the gas cap. Did you get gas recently? If so you may not have gotten the cap on tight.
Richard
Old Nov 21, 2006 | 10:29 PM
KdF's Avatar
KdF
EVAP Emission Control system leak very small
Old Nov 21, 2006 | 10:43 PM
AmericanMuscle4.6GT
ORIGINAL: 06GT4RAD
Richard
well here's what happened. noticed it a couple days after i got gas at about half tank. checked the gas cap, it was on tight. 5+ "driving cycles" and one monster burnout later, its still on. so i checked the code with a friends tuner. P0456. just as i suspected. but it's not going off for some reason. i'll have to inspect the cap tommorow carefully. also someone said something about a vacuum line being loose?
Old Nov 22, 2006 | 12:02 AM
jettblack06's Avatar
jettblack06
if you want to get rid of the light, use the tuner to clear it or unhook your battery cable and see if it comes back...damn epa and their evap..if they had to work on it they would think otherwise....
Old Nov 22, 2006 | 12:05 AM
06GT4RAD's Avatar
06GT4RAD
Use the tuner to clear the light and then drive it. Once the code is set it normally will not go out until cleared properly
Richard
Old Nov 22, 2006 | 12:11 AM
Haze28's Avatar
Haze28
My 2001 GT had this problem, dealership wanted to charge me $450 to change a vaccum line. I got a new gas cap, cleared the code and never had another problem.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Dathan
Oct 5, 2015 05:52 AM
