how do i install these things??
Old Feb 17, 2007 | 04:31 PM
policefordtuff's Avatar
policefordtuff
Default how do i install these things??
hey guys, i have the eibach pro kit on my car and im putting the panhard and adj lca's on today. i ordered a set of camber bolts from lmperformance.com and they sent me two bolts with a weird looking washer on it. now i havent looked under the car to see if i can figure this out yet cause i figured you guys could tell me. how does this system work??? i cant remember exactly how much negative camber i have but the tops bow in pretty good. i think the alignment guy said -1.75??? he said i was within ford specs but this just dont seem right. anywho i got the bolts so i want my tires to be straight up and down. can you tell me the easiest way to do these? any tricks or problems i should know about? thanks a ton guys!!
Old Feb 18, 2007 | 06:29 PM
Shaguarama's Avatar
Shaguarama
Default RE: how do i install these things??
I personally wouldn't mess with that. Take it to a shop that does allignments and have them put those on. Besides they are going to have to adjust the camber once they're on anyways. -Andrew
Old Feb 18, 2007 | 06:31 PM
howarmat's Avatar
howarmat
s197 Junkie
+1....alignment should be done by the pros.....you will being buying a new set of fronts if you get it off!
Old Feb 19, 2007 | 01:39 AM
Stoenr's Avatar
Stoenr
ORIGINAL: howarmat
What he said
Granatelli Sales
Jan 20, 2020 12:34 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
