Dyno Pull Numbers
Hi all,
had three pulls yesterday at the local dyno shop, using the PowerDync Mustang dynamometer. I wanted to share the numbers with you.
RWHP: top score of 264.5 (with WCF) @ 4857 RPM/112.9MPH
RWTQ: top score of 285.6 (with WCF) @ 4857 RPM/112.9MPH
The numbers would have been much higher, if it weren't for the fact I never used the LiveWire to move the electronic limiter up--once the computer hit the max, the exhaust let out a bit of black smoke, as if to tell the tech, "okay, no more".
Also, the tech did a calc which is typical for autos, and figured I had 355HP from the engine...so the conclusion was my mods I've done so far HAVE made a difference. That is, the CAI, 87 SCT tune, Borlas. The TB spacer has negative effect, I realize--just helps with throttle response.
I was a bit nervous running her up to the limit--I tend to baby my cars, but I was curious and the numbers, to me, were better than I was expecting. Once I get the 93 tune (after I drain this tank) and add the UDPs, I'll give it another pull.
You should have been seeing numbers near those stock. Im sure they gave some improvement, but it should have been more than that. A tune and intake is generally said to give around 25-30 hp, 20 at the least. Not to mention you have "cat-backs", what do you mean by that? To my knowledge there arent any "cat-back" kits out for our cars like there were for previous models. You either have an axle back, a different midpipe or header back system with this car. If its a different midpipe, you should gain about 5-10 hp depending on the crossover, and around 20-25 if its headers back. Youre showing improvement of about 10 over a stock auto (255 rwhp and 275 rwtq). Either you were tuned wrong or something is faulty, it just doesnt seem right...
You did indeed buy the right tuner, but I agree with the rest of the gang, its a canned tune, you could get more outta that puppy. get a tune. believe me. brenspeed, b ama, whatever, I would highly advise
