Horsepower Gains from Smaller Tires?
Old 04-05-2007, 02:34 PM
P Zero
P Zero's Avatar
Default RE: Horsepower Gains from Smaller Tires?
Its not the size that takes the HP its the WEIGHT.
-P.
P Zero is offline
Old 04-05-2007, 03:29 PM
wingman75
wingman75's Avatar
ORIGINAL: Lees07GT
To be sure, I would need to know what the optional 18 tire size is. But I believe that the overall tire/wheel height is approximately the same with the 18's having a lower profile tire than the 17's. Can you tell me the size of your tires?
I guess you are right about them being about the same considering the difference in aspect ratio. That went right over my head. But I did measure my 17 inchers tire width at 26-1/2".
Thanks!
wingman75 is offline
Old 04-05-2007, 03:39 PM
forensicsteve
forensicsteve's Avatar
This is why I am selling my Nitto DRs 315/35/17. They are slightly smaller in diameter than the stock tires, and this givesthe caran effective gear ratio of 4.34. Makes daily driving more difficult and carwould run out of 4th gear in the 1/4. For the track,we're going with 27.6" diamslicks that reduce the ratio to 4.04 but getus through the 1/4 (in theory anyway until next wednesday).
No idea about hp changes though.
forensicsteve is offline
Old 04-05-2007, 04:45 PM
Lees07GT
Lees07GT's Avatar
ORIGINAL: wingman75
ORIGINAL: Lees07GT
To be sure, I would need to know what the optional 18 tire size is. But I believe that the overall tire/wheel height is approximately the same with the 18's having a lower profile tire than the 17's. Can you tell me thesize of your tires?
Thanks!
Okay, I found the factorytire sizes in my owner's manual. The 17 is 235/55 and the 18 is 235/50. Doing the math, the 17 total tire height is 27.18". The 18 works out to be 27.25". So the overall size of the 17 and 18 tires/wheels are essentially the same and there would be no noticeable effect to gearing.
Lees07GT is offline
Old 04-05-2007, 04:49 PM
modular81
modular81's Avatar
I'm pretty sure the weight of the wheel and tire combo is what causes aincrease or decreasein rwhp on a dyno.
modular81 is offline
Old 04-06-2007, 02:33 AM
RodeoFlyer
RodeoFlyer's Avatar
couple things here -
first of all, you are NOT making any more power. your engine does not magically make more horsepower. you are putting it to the ground at a faster rate.
yes, shorter tires change your gear ratio, HOWEVER - you now have a smaller contact area on the ground. A 26" tall tire contacts less rubber to the ground in one revolution than a 28" tall tire. This means that per revolution even though they are the same width the taller tire puts more rubber to the ground. NHRA Stock Eliminator cars are a good example of this. They are only allowed a 9" wide slick, so they run 30" tall ones for a larger contact area. A taller tire will alsohave a larger sidewall to wrinkle better, allowing better traction. You will se NMRA guys running 28x10.5's much more than 26's.
RodeoFlyer is offline
Old 04-06-2007, 12:10 PM
2cokeman
2cokeman's Avatar
So the stock tire package on the mustang both in 17 and 18 inch should have really no difference??
2cokeman is offline
Old 04-06-2007, 02:32 PM
CrazyAl
CrazyAl's Avatar
ORIGINAL: 2cokeman
There is no appreciable difference between the two for gearing.
However, the 18" wheel-tire combo is slightly heaver and it also has higher rotational inertia not just from the weight but becasue the radius of the wheel is higher. Thus the 18" combo should be slightly slower than the 17" setup...but it is very minor.
CrazyAl is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Horsepower Gains from Smaller Tires?
