Today is the Day...3.2 Pulley/Dyno Tune *UPDATED*
#22
RE: Today is the Day...3.2 Pulley/Dyno Tune
ORIGINAL: hammeron
hey perdi, how is my stock clutch gonna hold up, with the new
found powah
found powah
I think it's good now aside from it coming in light under heavy load... Hopefully it will start to grab harder. I know guys that are pushing the same or a little more power on the stock clutch and it's holding fine... for how long I can't tell ya, but so far so good.. If your going for bigger power, I'd suggest strongly looking at the Dual GT500 Fuel Pump set up, and putting money there instead of the clutch...then the BMR UCA/LCA, and Panhard..
The only reason I really replaced it was I figured that the stock one was gunna burn up fairly quick, and since the car was having a ton of stuff done I figured I might as well... the original clutch only had 2,000 miles on it so..... maybe not the best move financially.
Now all I have to do is finish off the suspension, (lowering springs and D-Specs ( I think)).
#24
ORIGINAL: tonkpils555666sas
you going to change driveshaft or torque converter as well?
I have a manual tranny.
So really other than that I can't think of much more I can do...maybe the brakes?
#25
bad news for ya you're already there!
but i'll be showing up too, sooner or later......
ORIGINAL: Perdi
I was gunna do an aluminum driveshaft, but am holding off on that until the car is lowered... apparently there can be clearance issues with the aluminum driveshafts hitting the floorboard. It would be nice if I can put one in there...but dunno if it's 100% necessary. I will probably leave everything the way it is for now, cause now I'm contemplating a crate motor. Or Forged internals.... but because I bought the Saleen, I'm thinking just going to a crate motor. But, I'm going to think about that long and hard....cause for a street car / daily driver 700+hp seems like it could possibly be overkill.. And really might drive me to the looney bin..(all that power and never being able to use it). If I'm gunna up the power from where it is now I'm not "F'in" around, it would have to be a minimum of 700+ with the ability to go up over 1000. I really not interested in 500 or 600hp...If i'm going big, Im' going BIG.
09-08-2015 06:25 PM
