I gained HP with delete plates
ORIGINAL: tonkpils555666sas
well hopefullly BillyBob, I will be able to give you some numbers here soon. But maybe I miss read, FordFanBoy, can you explain the whole thing about dyno numbers are hard to determine if you are adding small amount of hp? I am curious because I want to make sure I get the most accurate tune for my car...
Hopefully you all understand that the butterflys without the Deletes are completely open at WOT and dyno pulls are made at WOT. So the only chance for the deletes to provide better flow is when NOT in WOT and/or during the periods they open/close. That is the only place (not WOT) where the deletes are offerring any difference what-so-ever from the stock assembly.
Rock - you are correct, the HP and torque are tied together mathmatically but there is no way to determine IMO that change if any on a dyno as the pulls are made under WOT.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
