Pinging
Old May 13, 2007 | 06:54 PM
2cokeman's Avatar
2cokeman
Default Pinging
My Stang is pinging when shifting into second and thrid only when on hard acceleration, I have only the stock tune with the K&N dropin, I tried 89 octane and the same thing, Can I run 91? on the factory tune??? Any ideas on what is causing it??
Thanks!![sm=dontgetit.gif]
Old May 13, 2007 | 08:48 PM
Daniel60's Avatar
Daniel60
Default RE: Pinging
It saids in the manual if it pings a little like the example your speaking of don't worry about it. But if it pings all the time go to the dealer.
Page 209 in my 2005 manual it saids
If you are experiencing starting rough idle or hesitation driveability problems, try a different brand of unleaded gasoline. Premium unleaded gasoline is not recommended for vehicles designed tu use Regular unleaded gasoline because it may cause these problems to become more pronounced. If the problems persist, see your dealer or qualified service technician
It should not be necessary to add any aftermarket products to your fuel tank if you continue to use high quality fuel of the recommended octane rating.
Do not be concerned if your engine sometimes knocks lightly. However, if it knocks heavily under most driving conditions while you are using fuel with the recommended octane rating, see your dealer or a qualified serivce technician to prevent any engine damage.
Old May 14, 2007 | 12:02 AM
2cokeman's Avatar
2cokeman
Default RE: Pinging
That just about sums it up, I might as well get a tune??
col2560
Dec 11, 2015 10:18 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
95_GT_Stang
Jun 10, 2005 09:36 AM
edjuk8r
Jun 7, 2005 09:17 AM
GT1999
17
Mar 24, 2005 04:18 PM
