bottom end
Old Jul 6, 2007 | 01:34 PM
wentw1tj5773's Avatar
wentw1tj5773
Default bottom end
What bottom should I go with to replace the bottom that is in my 4.6 3v motor in my 06 gt. Later I want to run the Whipple supercharger systems. Any help would be great
Old Jul 6, 2007 | 01:37 PM
majustin1's Avatar
majustin1
Default RE: bottom end
By bottom, do you mean rear-end, as in rear-end gear? If so, i would go with a FRPP 3.73. If that is not what you mean yuo may want to explain just a tad more.
Old Jul 6, 2007 | 01:44 PM
moosestang's Avatar
moosestang
He means the rotating assembly i'm sure. You know, crank, rods, pistons, etc..
Old Jul 6, 2007 | 02:08 PM
Dex's Avatar
Dex
Eagles stroker kit. i know RPM has it and I cant remember the place I got it. PM me if you want their number
Old Jul 6, 2007 | 02:20 PM
millerc73's Avatar
millerc73
Check out the MMR 2005-07 Mustang Annihilator 4.6 Shortblock, good for 900 hp and a pretty good deal.
http://www.modularmustangracing.com/
Old Jul 6, 2007 | 02:21 PM
majustin1's Avatar
majustin1
That makes more sense and would be a great idea. I asked about one the other day, but i mostly know them as stroker kits. I did not get much help, so better luck to you.
Old Jul 6, 2007 | 08:42 PM
Stage4's Avatar
Stage4
i'm using the MMR 5.0L stroker motor with about 5k on it now. The motor is great, zero issues, not too noisy. Their price was the best of everyone i looked at, my only issue was late delivery -almost 2 weeks after promised date.
Old Jul 6, 2007 | 09:43 PM
baha's Avatar
baha
ORIGINAL: wentw1tj5773
Here you go:
www.seanhylandmotorsport.com
www.dssracing.com
www.livernoismotorsports.com
Just make sure to keep the compression down (8.7:1-8.2:1) when ordering so you can turn up the boost
flash_xx
Oct 16, 2015 07:23 AM
kevsgt
Oct 9, 2015 10:12 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
