A quick, unique question
Old Jul 29, 2007 | 06:44 PM
cooper's Avatar
cooper
Default A quick, unique question
Lets just say that my car was stock. I wanted to install the 4:10's by themselves. Would I be able to use the SCT Xcal 2 to adjust the gear ratio without uploading a tune?
Cheers
Cooper
Old Jul 29, 2007 | 06:59 PM
s197richie's Avatar
s197richie
I ♥ Acer
Default RE: A quick, unique question
Since the only way that I know of to change your gear ratio and wheel and tire size (revs per mile) on the xcal is to reload your tune and opt to change the parameters between the steps of selecting the tune and loading it, I don't think so...I may be wrong...but if I'm right, I suppose you just have to find someone with an ODB2 scantool, they should all do it, and if worst comes to worst, find out what a shop would charge...I may be way off on this, but I don't see how...even if you loaded a tune with parameter adjustments, and then returned the vehicle to stock, the adjusted parameters would go back to factory along with the tune, right?
Old Jul 29, 2007 | 07:01 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
You can adjust the rearend ratio with the tuner. You will need to go through the reprogramming process still though on the programmer.
Old Jul 29, 2007 | 07:06 PM
howarmat's Avatar
howarmat
s197 Junkie
Technically you have to install a tune.....its a modified stock tune.....all that is changed is the stuff you mess with. Nothing else is touched.
tmdm
May 2, 2021 02:49 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
