Too lean.
Old 07-31-2007, 06:56 PM
white07
white07's Avatar
Default Too lean.
When I was trying to clear my CELs with my tuner it told me that 2 of the CELs were b/c I was running too lean. What shoudl I do in order to correct this?
white07 is offline
Old 07-31-2007, 07:07 PM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: Too lean.
too lean is too generic.....it will say that because you have an o/r pipe and headers.....what was the actual code.....
howarmat is offline
Old 07-31-2007, 07:11 PM
white07
white07's Avatar
P0171 Sys Too Lean 1
P0174 Sys Too Lean 2
What happened was I had my tuner tuned for all of my bolt ons but when my car wouldnt start with the charge motion delete plates and TB we just took those parts off and we threw the stock tune back on. So im running the stock tune with CAI, LTs, o/r x-pipe.
white07 is offline
Old 07-31-2007, 07:15 PM
moosestang
moosestang's Avatar
You have lost your ****ing mind my friend.
ORIGINAL: white07
moosestang is offline
Old 07-31-2007, 07:20 PM
slySTANGguy
slySTANGguy's Avatar
If you CAI has a larger MAF housing, like a C&L or JLT or one of them, then that is why you are running too lean. With the stock tune you should either have a K&N or stock airbox and plumbing.
slySTANGguy is offline
Old 07-31-2007, 07:27 PM
white07
white07's Avatar
ORIGINAL: moosestang
ORIGINAL: white07
well I depend on my car to get to and from work and the cmcv arent working on my car. Ill try installing the Tb and installing the tune but it wouldnt start before like that.
white07 is offline
Old 07-31-2007, 07:35 PM
howarmat
s197 Junkie
howarmat's Avatar
You never want to run the CAI without a tune!!! the 2 codes are because you have an O/R pipe....the tune would shut those readings off. You really are running lean because of those codes....you are however running with a bomb with that CAI and no tune.....take the CAI now....and you really shouldnt run the LTs and o/r pipe with out the tune but you would hurt anything bad.
Moose is right...you do not seem to have a clue to what you are doing right now with the risk you are taking....
howarmat is offline
Old 07-31-2007, 07:55 PM
moosestang
moosestang's Avatar
I depend on my car to get to work as well. I would have thought somewhere along the way you would have picked up on the fact that you can't use a CAI without a tune. Not to mention the long tubes and lack of cats. All of these things require retuning the engine.
I seriously doubt the TB and delete plates caused the car not to start (unless you forgot to hook something up). It was the tune that caused it not to start. Where did you order the tune from?
ORIGINAL: white07
ORIGINAL: white07
Old 07-31-2007, 08:08 PM
white07
white07's Avatar
ORIGINAL: white07
ORIGINAL: white07
I got the tune from B@m@chips. Everything was hooked up I checked it once and checked it twice. Im going to get a tune via email tomorrow for the parts that are on right now.
white07 is offline
Old 07-31-2007, 08:16 PM
hammeron
hammeron's Avatar
ok, all is forgiven
i hope it starts and runs perfectly right from the git go
ORIGINAL: white07
hammeron is offline
Quick Reply: Too lean.
