Help with Transmission/Differential Fluids.
I have a 2006 Mustang GT manual transmission.
I was wondering if someone could help me with what kind of transmission fluid and differential fluid Ford says to use when changing them.
Thanks!
Thanks!
RE: Help with Transmission/Differential Fluids.
MERCONĀ® Multi-Purpose Automatic Transmission Fluid XT-2-QDX Capacity 3.0L (6.3 pt)
SAE 75W-140 High Performance Rear Axle Lubricant XY-75W140QL
Approximate axle fill capacity
1.7 liters (3.15 pints) to the bottom of the fill hole with the axle at ride height
Additive Friction Modifier XL-3
118 ml (4 oz)
118 ml (4 oz)
I read for manual you are supposed to use the following..
Tranny:
Motocraft ATF
Rear End:
Motocraft SAE 75W-140 Synthetic Rear Axle Lubricant
Then add 4oz of Additive Friction Modifier XL-3.
Is this the same as what you said to use?
that's what they use in most ford manual trannys, my 91 GT with a T5 also used the ATF.
the fluid spec's and capacity are right out of the shop manual that I have access to here at the
Ford/Lincoln/Mercury dealership that I work for.
Keep in mind that you can run Mercon 5 in these trannys too without any ill effect. Supposed to be synthetic--smoother operation, runs cooler, etc. etc.
Testtester
V6 General Discussion
03-05-2014 08:24 PM
