HELP READ PLEASE
Old Sep 25, 2007 | 07:12 PM
kleistang's Avatar
kleistang
Default HELP READ PLEASE
So i decided to clean my spark plugs today, after i carefully cleaned them and puted the back on, i started the car and
it is runing real rough, 2 codes came out
P2107 Throttle Actuator Control Module Processor
P2110 Throttle Actuator Control System - Forced Limited RPM
i have no idea whats going on, i drove the car around the block and it is missfiring like crazy. does anyone has any idea, i tried unpluging the negative from the battery, loading stock tune and reloading 93 tune, i have an SCT programer, JLT CAI and SLP's a/b the rest are suspension mods, the car has 16k miles on it.
Old Sep 25, 2007 | 07:16 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: HELP READ PLEASE
hmm, did you put the same plug back in the same place...
Old Sep 25, 2007 | 07:19 PM
22kart22's Avatar
22kart22
make sure the plug boot is on tightly
kleistang's Avatar
kleistang
all of the in the right place, coil on plugs and plugs are in the right place
Old Sep 25, 2007 | 07:24 PM
howarmat's Avatar
howarmat
s197 Junkie
may i ask what you did when you cleaned them and why??
Old Sep 25, 2007 | 07:28 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Did you unpug anything? And if so did everyhting get plugged back in?
Old Sep 25, 2007 | 07:30 PM
kleistang's Avatar
kleistang
i used t/b cleaner and a wire brushto clean them cuz the were build up with rust anc carbon,
Old Sep 25, 2007 | 07:31 PM
kleistang's Avatar
kleistang
the only thing i unpluged was the t/b position sensor but i pluged it back on
Old Sep 25, 2007 | 07:53 PM
drbobvs's Avatar
drbobvs
I bet there's something disconnected. Check all the wires to the plugs and make sure all are put back to the proper coil. Look at the TB connector too. Lastly make sure all coils are properly secured to the top of the plugs.
Old Sep 25, 2007 | 08:06 PM
mlcrycc's Avatar
mlcrycc
ORIGINAL: howarmat
Since I have not done plugs yet at 15K, is this important to do?? I mean same plug back in same cylinder.....
Mike
