Just my thoughts on the Saleen SC
Old 11-09-2007, 10:22 AM
sevenleaf
sevenleaf's Avatar
Default RE: Just my thoughts on the Saleen SC
ORIGINAL: tim281
Could you see any baffles or butterfly valves whenyou took off the top part of the supercharger? Now you got me wondering what exactly this actuator is controlling inside the supercharger.
Does anyone have any other experience adjusting the bypass valve on their charger?
the bypass valve? Are you talking about the pump actuator?
When you take the top of the supercharger all you can see is the intercooler and maybe oil? (I didn't take a real close look at the fluid we were getting tired.) We didn't takethe intercoolerout though. We were hoping to see a lot more.
sevenleaf is offline
Old 11-09-2007, 11:40 AM
HaneyMotorsport.Com
Banned
HaneyMotorsport.Com's Avatar
Ok guys, here is how it works..........
There is a butterfly attached to a shaft (like a carb or t.b.) that extends outside of the blower housing. The dashpot, vacuum valve, whatever you wish to call it moves the shaft open or closed. The first 2 pics show the valve closed / dashpot arm contacting the stop screw.This is the position when engineis off orunder boost..no vacuum. Second pics are valve open / dashpot arm Not contacting stop screw. This is when engine is at idle or cruise...vacuum present.
Turningin the stop screw will make the butterfly close more, turning out ,will open more. I do not recommend, suggest, advise, etc. modifying the setting. There is a good chance that the butterfly (if closed tofar) may bind in the bore. If this happens, under full boost, high rpm, once you let off the throttle, the boost will not bleed off!
This set up may seem cheap, half ****, etc. to many people. BUT, it is a simple yet very effective design. Look at Ford's factory supercharged cars/trucks. They are the same design.
Casey
[IMG]local://upfiles/34215/154E87EB5FC74C5BA7C30CE99DE7B798.jpg[/IMG]
[IMG]local://upfiles/34215/8F53C3398B1D4CF0AAD96AC84C9203D6.jpg[/IMG]
[IMG]local://upfiles/34215/3DA3B73BCB2642E38827FF13FF78EB3E.jpg[/IMG]
[IMG]local://upfiles/34215/DBC682C50DB0479499A52DD6982926F4.jpg[/IMG]
HaneyMotorsport.Com is offline
Old 11-10-2007, 12:08 PM
tim281
tim281's Avatar
Casey you rock! That is a great explaination and it makes total sense. I wish Saleen would use something a bit morepermenant when they set the position of the nut on the screw...perhaps somewashers between the head and bolt, tack weld it,orsomething.....because a small plop of wax is very easy to move around. I knowmine moved a few timeswhen I installed the screw, but Ithink I was able to get it back to its orignal position.
tim281 is offline
Old 11-10-2007, 01:56 PM
06Saleen3V
06Saleen3V's Avatar
ORIGINAL: sevenleaf
I really dont wanna sound dumb but are those the injectors with the red caps
06Saleen3V is offline
Old 11-10-2007, 02:16 PM
drbobvs
drbobvs's Avatar
No, those are the coil-on-plugs, made my MSD.
drbobvs is offline
Old 11-10-2007, 11:32 PM
06Saleen3V
06Saleen3V's Avatar
ORIGINAL: drbobvs
What is their function?
Old 11-11-2007, 02:32 AM
Diabolical!
Diabolical!'s Avatar
ORIGINAL: 06Saleen3V
ORIGINAL: drbobvs
To provide better spark.
Diabolical! is offline
Old 11-12-2007, 07:04 AM
sevenleaf
sevenleaf's Avatar
ORIGINAL: HaneyMotorsport.Com
Casey
Thanks a ton for this explained it perfectly.
Old 11-12-2007, 10:47 AM
ModernMuscle
ModernMuscle's Avatar
06saleen, check under your hood, yours are black factory. they really arent needed until you get some boost, and even then, its rare to need them.
some do, some dont, but in the end, its a $400 for about 3-5 hp.
ModernMuscle is offline
Old 11-12-2007, 12:38 PM
06Saleen3V
06Saleen3V's Avatar
ORIGINAL: ModernMuscle
Sounds like a bad investment to me
Quick Reply: Just my thoughts on the Saleen SC
