Which mods reduce low end torque?
ORIGINAL: Norm Peterson
But that's only half the story, the half that assumes that you're racing.
The other half addresses throttle response under the more normal daily-driving conditions where under 3000 rpm covers 99+ % of the time and distance. I suspect that the OP wants to know whether it's barely noticeable or if it's bad enough to make it feel like you've always got the tranny in about one too high of a gear.
Norm
ORIGINAL: ratnacage
I guess I'm not sure why anyone would be concerned with the effect of a mod that's minor to begin with, below 3000 RPM. If you're racing, your engine should never see less than 3000 rpm anyway so whatever's going on below 3000 rpm is moot (once you're out of first gear, the engine should stay above 4000).
Norm
I wonder how closely the single-plane vs RPM-oriented dual plane carburetor manifold comparison works as an analogy here . . .
Norm
Norm
The CMP's (charge motion plates)in our cars don't change the overall volume of the intake runners so intake velocity shouldn't change - HOWEVER, air will accelerate around a throttled CMP, and if they're close enough to the intake valves, then maybe they'd have the same effect. But as I understand it, the CMP's serve only to induce turbulence which promotes better fuel mixing at lower rpm. I'll leave open the possibility of being very wrong on that point however.
OK, I'm beginning to get a picture. A cc or so of material that provides throttling isn't going to affect the volume enough to matter much, but the effect on the velocity field will, and I'd certainly expect that to be somewhat RPM-sensitive.
Does anybody have any real pictures of the OE CMP's? I'm beginning to wonder if they bias flow toward one of the two intake valves, affecting swirl and tumble within the cylinder.
Norm
Norm
ORIGINAL: ratnacage
True, but let's look at the big picture. The WOT gains are less than 10 across the board, so even using very ambitious assumptions, that's less than 4% of the output at 3000 RPM (assuming 240 rwtq at 3000 rpm). Now look at part throttle and you're talking gains or losses that are virtually undetectable. The bottom line is you don't need a dyno to find the answer to the original question. This is in no way a swipe at the OP, but too often people get themselves buried in graphs and dyno numbers and fail to step back for a moment to look at the bigger picture.
Norm
ORIGINAL: ratnacage
Norm
Obviously if I was racing I would be above 3k so the benefit of the reduced restriction would be noticed but unfortunately I don't road race evey day.
I've got an O/R h-pipe and CMDP's and I didn't notice any low end torque loss.. I did pick up 14rwhp from the delete plates and O/R pipe. I could care less if I lost torque below 2k if anything it helps me take off easier next to cops. If I'm racing it doesn't even come into effect.
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
