P0174
Old Jan 4, 2008 | 02:10 AM
swensicle's Avatar
swensicle
Default P0174
Got this code today.It looks like an O2 sensor. I've heard it might be wise to clean out the MAF sensor with some brake clean and see if that does it. Any other suggestions? Thanks guys and gals!
Old Jan 4, 2008 | 03:22 AM
moosestang's Avatar
moosestang
Default RE: P0174
A code P0174 may mean that one or more of the following has happened: [ul][*]The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters (K&N, etc.) can cause the MAF to become dirty if the filter is over-oiled[*]There could be a vacuum leak downstream of the MAF sensor.[/ul] Possible Solutions Possible solutions include: [ul][*]In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling[*]Inspect all vacuum and PCV hoses, replace if necessary[*]Check for a dirty fuel filter and proper fuel pressure[/ul]
Cleaning the MAF couldn't hurt. I've cleaned mine 1/2 a dozen times or more with brake cleaner. I just give it a 2 mississippi blast.
Old Jan 4, 2008 | 10:23 AM
DarkFireGT's Avatar
DarkFireGT
Default RE: P0174
Check your intake tubes also, and make sure everything from the maf to the tb is tight.
Old Jan 4, 2008 | 12:34 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: P0174
Thats the code I got when i put the catless midpipe on, turned the rear 02s off with my predator, no more code
Old Jan 4, 2008 | 04:15 PM
swensicle's Avatar
swensicle
Default RE: P0174
Well guys, for now I just decided to clear the cel and see if it comes back. So far so good, and if it comes back I'll probably try cleaning the MAF with some brake clean. Thanks for your help! Can you guys imagine not having this resource?....I love being able to talk to guys and girls with the same car as me.
Old Jan 4, 2008 | 04:18 PM
aode08's Avatar
aode08
Default RE: P0174
im shocked none of the guys havent told you not to use brake cleaner on a Mass Air Flow Element.
Its Electrical Contact Cleaner Spray
Jb145700
Aug 21, 2022 06:37 AM
01blackgtconv
Aug 14, 2015 04:50 PM
kingrukus
Jul 31, 2012 10:01 AM
bbayne
Mar 16, 2012 12:54 PM
bonsaicult
Apr 18, 2007 10:38 PM
