header hits steering shaft
Old 01-11-2008, 08:57 PM
memphis90
memphis90's Avatar
Default RE: header hits steering shaft
I've noticed in the ads from places selling the OBX lt's that they show 2 H-pipes. What's the deal?
memphis90 is offline
Old 01-11-2008, 09:29 PM
jawsgt
jawsgt's Avatar
yes thats correct it comes with both h-pipes off road and catted
jawsgt is offline
Old 01-11-2008, 11:24 PM
Simon1
Simon1's Avatar
I had less than 1/8 clearance and it cured my problem. It prevents the motor from shifting from side to side under load.
Put new mounts in and your done.
Simon1 is offline
Old 01-11-2008, 11:28 PM
lrgnation
lrgnation's Avatar
if you went slightly higher quality than OBX... then none of you would be having these problems.
lrgnation is offline
Old 01-12-2008, 02:41 PM
aircare84
aircare84's Avatar
Sorry to say, but the OBX's aren't the only ones that have clearance issues with the steering shaft.
The 2 H-pipes that come with the OBX include 1 with resonators, not cats & 1 straight thru H. No cats are included.
aircare84 is offline
Old 01-12-2008, 03:24 PM
jawsgt
jawsgt's Avatar
if i were to put the resonator h-pipe on would i lose any power and would that get rid of sum of the raspyness around 3k?
jawsgt is offline
Old 01-12-2008, 07:40 PM
aircare84
aircare84's Avatar
I wouldn't imagine you'ld loose any power, it's a straight-thru piece. Can't comment on the 'raspiness' as I've only had the H w/resonators on mine so far. Only time I really notice it on mine is when I shift above 3K,get a little between shifts.
I'll probably try the straight H later when it gets warmer & I can cruise with the windows down again.
Old 02-25-2011, 08:10 AM
mjk
mjk's Avatar
which motor mounts did you guys use? also, I saw that someone mentioned that they raised the engine. Does that happen in all cases? I have an FAP blower, and would most likely run into issues if I raised the motor...
thanks
mjk is offline
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
ChampInSD
10-02-2015 04:55 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
09-30-2015 12:39 PM
Quick Reply: header hits steering shaft
