wat gauges for supercharger
RE: wat gauges for supercharger
my SC and gauges are going in right now, i got wideband A/F, mechanical boost, electric fuel pressure. you can get the gauges anywhere like lethal, jegs, etc, just depends what you like the looks of best. i also got the SOS pillar pod. also i got delayed bc i need an adapter for the fuel pressure gauge that taps into the fuel line. so if you do get fuel pressure gauge dont forget the adapter. i think those 3 gauges would be great for monitoring any SC.
ORIGINAL: onederful100
I have all autometer ultra-lite gauges and an SOS triple pillar pod.. Electric fuel pressure, electric boost, and wideband. I find electric boost is easier to run, because you don't have to push the nylon tubing through the firewall where it tends to kink.
ORIGINAL: lorinczy07
wats the difference between electrical and mechanical and which is better? and also for the air/fuel ratio wats the difference between wideband and short. thanxs man
Mechanical boost is better (in some ways) because it will respond to changes in boost more quickly. Also there is a cost benefit. Fuel and oil temp/pressure, etc, are good candidates for electric gauges because it allows you to keep fuel and oil outside of your cabin. As others said, narrowband A/F is relatively useless; you really need to go wideband.
ORIGINAL: BlackBetty
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
