Gauges<--Help me out guys
#21
RE: Gauges<--Help me out guys
ORIGINAL: blackS197
Is it accurate? If its not directly connected somehow how does it know the intake temp and coolant temp?
ORIGINAL: moosestang
the aeroforce gauge simply plugs into the obd2 port under the dash. there's no other wires to run.
It will display a gazillion things and it reads and clears trouble codes just like a tuner. Did I mention it records 0-60 and 1/4 mile times?
ORIGINAL: Darkness7
Sounds like a winner to me. I guess its worth the money considering all the parameters that you can track. How involved is the install?
Basically you can read anything the computer tracks.
I personally like to see the IAT after the blower and teh coolant temp, so I know when its warmed up and I can punch it. Eventually I will set up some of the more advanced features.
After my new clutch and tires (next year) I will take the car to the track and run the gauge (Performance numbers, 0-60, 1/8miles, 1/4 miles) against the lights to see how close it is. In the mean time the numbers are just for fun.
