Idle problem
Old Mar 16, 2008 | 12:17 AM
98BlackStang46's Avatar
98BlackStang46
Default Idle problem
I own a 05 GT and sometimes when I first start the car in a while it seems to have a rough idle does anyone know if this is normal
Old Mar 16, 2008 | 11:18 AM
hammeron's Avatar
hammeron
Default RE: Idle problem
doesn't sound normal
could be throttle body (needs cleaning) or
fuel filter
Old Mar 16, 2008 | 12:02 PM
GidyupGo's Avatar
GidyupGo
Rough idle for how long? If it doesn't do it any other time, it isn't a clogged fuel filter or dirt some where. It would do it all the time in those times. I think it is a combination of it sat for an extended length of time and it is cold.
Old Mar 16, 2008 | 03:43 PM
75gmck25's Avatar
75gmck25
I don't have a good answer to your question. However, I have noticed that my 2005 GT is noticeably louder (the exhaust actually sounds better) at cold startup, which probably means the engine controls are doing more than just running richer to overcome the cold engine. If your car's computerisn't making the right adjustments to compensate for the cold engine, it will probably cause driveability problems at startup.
My best guess would be a fuel pressure problem. Your car needs a constant high pressure fuel feed, and a partially clogged filter or a fuel pump that is slow coming up to full pressure could cause startup problems. Its probably also causing full throttle fuel flow problems, but the reductionmight so slight that its hard to feel.
Bruce
Old Mar 24, 2008 | 05:20 PM
98BlackStang46
It only does it after its sat all night and I crank it up to go to work in the morning... It only does it in cold weather too usally somewhere between 30-40 degrees... It only does it about 10 seconds
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
