LCA'S AND LINE LOCK INSTALLED
Got the BMR Lca's and SLP line lock installed yesterday, with a ton of help from Simon1 (he did about most of the work). Noticed a big difference in traction with the lca's but I do still break loose in second but not as often. The line lock works get, I will post a video soon. If any one is interested in seeing pic's I can take some of the completed install, didn't take any during, but we still need to install the line lock on Simon1's car.
The lca's and relocation brackets were easy, the line lock was easy with the exception of the solenoid, but that only added but 30-45 minutes to the install.
RE: LCA'S AND LINE LOCK INSTALLED
To me the LCA's alone did nothing compared to the addition of the bigger rear sway bar+LCA's. My sway bar was on backorder when I put my LCA's on and though there was a difference, I put the sway bar on and it was a completely different animal.
ORIGINAL: blueherd02gt
I'm going to post our little race in the S/S section.
Make sure you chime in with your excuses!!!!
The solenoid was the hardest part by far. Had to drill from the outside of the fender well. We had the angle drill bit but it busted. But other than the solnoid it was pretty easy. The lines fit good no leaks, and as far as how it worked?? It fricking worked great! I am buying stock in BFG tomorrow!
I have read most systems do well with the ABS on our cars from any of the big aftermarket companies. Sactown and Simon1 congrats and i look forward to watching the video! J
