Torq on lugnuts?
Old Apr 30, 2008 | 11:01 AM
Androdz2's Avatar
Androdz2
Default RE: Torq on lugnuts?
never used a torque wrench for lug nuts no problems yet. I just put all the lug nuts then proceed to tighten a bit on a across pattern then really torque them down with the same across pattern.
Andrew
Old Apr 30, 2008 | 01:19 PM
F1Fan's Avatar
F1Fan
ORIGINAL: Androdz2
Andrew
If Andrew is not using a torque wrench we should all take is asa sure sign that using a torque wrench is mandatory.
Old Apr 30, 2008 | 01:27 PM
F1Fan's Avatar
F1Fan
ORIGINAL: rshamekh
Do you actually have to torque them to 100lb? I just tighten them until they are tight enough!
Hell I didn't even use a torque wrench to torque down the manifolds bolts after my cmdps install.
I should be fine, right?
Hi rshamekh,
Back in the olden days of stamped steel wheels itdid not matter a lot as the steel all generally expanded at the same ratedrum brakes and all. Modern cars with alloy wheels and steel brakes are designedto haveconsistent torque all around to preventdistortion of the rotors and wheel hubs and to promote brake cooling.So as long as you are parked in your garage you will be fine. But when your wheels fall off or you start to get brake vibrations or even if you get lucky andnot torquing the wheel lugs properly doesn'tcause you any obvious problems you will bemuch better off in the long run if you hand torque your alloy wheels toFord specs.
HTH!
Old Apr 30, 2008 | 02:02 PM
MartyMoose's Avatar
MartyMoose
The guys at a local tire shop (big name tire shop) will mount the tire, finger tighten the lug nuts, set their torque wrench and then proceed to crank the **** out of 'em. Like putting their body weight into it LOL. WTF?![8D]
[sm=chairshot.gif][sm=headbang.gif][sm=icon_stickpoke.gif][sm=laughat.gif][sm=loser.gif]
[sm=owned.gif]<--- Me the next timeI try to take my tires off. Time to get a breaker bar, I guess.
Old Apr 30, 2008 | 05:01 PM
LS1less's Avatar
LS1less
I have used a Q wrench on lugs with all my cars & have never busted a stud. It may be overkill to some but thats what I do.
Old Apr 30, 2008 | 06:03 PM
rshamekh's Avatar
rshamekh
Thanks for the clarification F1Fan.
Old Apr 30, 2008 | 06:11 PM
modaddict's Avatar
modaddict
100 ft lbs for most wheels and 80-85 ft lbs for aluminum lightweight wheels...
Old May 1, 2008 | 02:31 AM
Androdz2's Avatar
Androdz2
ORIGINAL: F1Fan
ORIGINAL: Androdz2
Andrew
lol I see that you are still bitten by the fact that every argument you have ever had with me you have lost. Still recommending stage 4 cams for fi?, or are you still stating a big brake kit does not have more brake tq than a small diameter brake kit? Or best yet are you still recomending to shift at 7.2k or 6.9k I dont remember correctly because you could stay in gear longer and put more power to the ground lols
Andrew
Old May 1, 2008 | 07:59 PM
Aziraphale's Avatar
Aziraphale
ORIGINAL: rshamekh
For the record, I did the same thing as you did before I had a torque wrench (on past cars). Since I bought one a few years ago, I torque them properly now.
Tomzwheels
Jun 20, 2006 02:37 PM
orange04
May 21, 2006 10:55 PM
bgbdstang
Feb 15, 2006 12:31 PM
Hiboost
Jan 16, 2006 06:54 AM
