Hard starting after sitting for a few hours
RE: Hard starting after sitting for a few hours
5-10 seconds I dont see a big increase. Playing on the highway for long periods in the throttle, or back to back quick acceleration runs I have seen it get quite high.
But if you just stab it and go it takes a bit to climb.
I have this same problem in my 08. It only has 3000 miles on it and I have a C&L intake and Brenspeed tune. Every now and then after sitting for a while I will try to start it and it will just crank and crank and crank, and then finally when it hits it runs ragged as hell for a little while and blows out a bunch of smoke. It's like it just sits and floods itself for some reason. I wouldn't think its tune related as I have the same mods as a million other people. I guess I should go try cleaning the intake sensors first and see if that helps. I just don't see why with it being off how it manages to flood itself?
I found a solution: don't wait for the fuel pump to prime.
I usually let the fuel pump makes its noise, then turn the key. If I start the car cold, without letting the pump prime, it starts right up like normal.
You are right as well as moose! I had a cold starting issue when cold 40 or lower...resolved with a tweak of the tune! J
ORIGINAL: MustangGT0405
Good idea, I think that will cure alot of your problems.
MYGT500 - had a cold start issue I think that was tune related.
Good luck with the build.
ORIGINAL: CataclysmGT
Did you get the FRPP tuner yet?
Also I dont let the pumps prime I just turn it over. Dont get many cold starts in FL though, its been in the 90's lately.
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
