Problem removing stud from manifold
Old May 13, 2008 | 01:30 PM
WFdeac11's Avatar
WFdeac11
Default Problem removing stud from manifold
I began to install my full assembly slp xpipe today, and ran into a problem. I unhooked the sensors and removed the stock h pipe, and then started to remove the stud from the manifold. However, a 16 mm socket was too big and a 15 mm socket was too small. I also tried the US system with a 5/8 and 9/16, but turned out the same results. Is there some special socket I need to buy, or is something else wrong? Any help would be great. I'm ready to get this thing installed. Thanks.
Old May 13, 2008 | 01:41 PM
hammeron's Avatar
hammeron
Default RE: Problem removing stud from manifold
i ran into the same thing on
one of my projects...
i bought another tool and the
difference in manufacturing, made
the difference for me
Old May 13, 2008 | 03:47 PM
WFdeac11's Avatar
WFdeac11
I was wondering why I even need to remove the studs from the manifolds. It seems like I could just attach the pipe and reuse the studs, but the instructions say to remove them and use the bolts provided. It just blows my mind that neither the 15 (which I think should fit) or the 16 fit! Thanks for the suggestion Hammeron... I don't know what else could work.
Old May 13, 2008 | 07:37 PM
drbobvs's Avatar
drbobvs
Just reuse the stock studs. If you can't for some reason. try using a Craftsman Pocketsocket, sear also makes something like this which is my favorite, the harder you pull, the tighter it grips. I don't know the name it's sold under though but I got mine at Sears.
Granatelli Sales
Jan 20, 2020 12:34 AM
spamedic
Sep 9, 2015 12:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
