Intake Runner Manifold P2004 P2005
i have a 07 mustang gt. i just installed the long tube mac headers from brenspeed. pain in the butt to put on with just ramps but now i get these codes P2004 and P2005. i tried to find as much information on here before i post but none really helped. the only thing i had bad problems with was the o2 sensors extensions werent long enough so we pulled the plastic coverr off soome from the factory o2's and they fit. and i drive it for a lil bit then tripped the codes. and brenspeed isnt open till tuesday and i need help. any information or help would be greatly appreciated! and also will it hurt my car to came driving it with the codes tripped?? thanks!
RE: Intake Runner Manifold P2004 P2005
Have you gone through and checked exhaust for leaks? Or possibly wiring came loose somewhere in your engine compartment?Or it could be you just need a re-tune with the new headers. I dont know what the codes are though. How does it run?
P2004 (INTAKE MANIFOLD RUNNER CONTROL STUCK OPEN - BANK 1)
P2005 (INTAKE MANIFOLD RUNNER CONTROL STUCK OPEN - BANK 2)
Have you tried to clear the DTC's? The link below might give you a couple of things to check.
http://www.bmcf0rums.com/sh0wthread.php?t=43338
Replace the 0 with o in the link
yea i have checked for leaks. dont seem to find any but im still going to exhaust shop to get the to weld the pipe from the headers to the prochamber h-pipe. car runs pretty good i guess. its not that loud either. its about the same as it was before the headers were on with the sound that is. feels a bit stronger when hitting the gas. appreciate the info the SACTOWN. i was thinking of clearing them and then see what happens.i am using the xcal2 and the tunes from brenspeed, but when i bought the headers i asked if i needed to have the tuner retune for the install of the headers and he told me no. its just weird that i didnt mess with any of that stuff and now theres a problem with it. Now do any of you guys know if this will hurt the engine if i keep driving it like it is? thanks again
well so far so good. i ended up having to delete the codes about 3 times and start it a couple. and now the engine light is off. hopefully for good! i really appreciate all the suggestions and help i got. THANKS!
daltron
04-28-2016 08:10 PM
