Procharger guys look here
I did the Steeda tubular radiator support this weekend and had a problem. With the Pocharger lower pulley and the BMR k-member I only had about 1/2 in. clearance between the BMR sway bar and the Procharger pulley and after the Steeda install the Procharger pulley rubbed the sway bar pretty bad so I had to install 3/8 alum. blocks (that I made myself from flat stock 3/8 x 2') between the Steeda support and the frame/body. So just a heads up if you have all of these mods together or are planing on these mods. I would think front end weight might have something to do with some haveing issues and some not but this is just my experience hope it can help some ?[/align]
RE: Procharger guys look here
Im assuming you saw the Myspace stuff, that was the old setup for the new stuff look here https://mustangforums.com/m_4739459/tm.htm.
Ok I need some major help...I just installed my procharger on my 01 Mustangg GT and I am having issues with oil coming out from where it bolts up at. I think this has to do with maybe that bolt being an oil seal but other than that i am drawing a blank! HELP!!!
Dragonus18
09-09-2015 01:21 AM
