NITROUS SETUP
Ok, i love forced induction, dont get me wrong. i cant afford the int price for a FI system. either way i was going to get an eagle roating assembly. with that being said, could i run a 2 stage 150 + 150 setup on c16 with a 10:5:1 c/r from je. ? stock heads. dual pump fuel setup. colder plugs, custome tune. right now i run 12.86@107 all motor. its an auto by the way. i wold like to run low 11's.
So you want to run a 300 shot of nitrous?
the 10lbs bottle will only last you like 2 runs, maybe. At 40 bucks a refill, that is a killer for me. FI for me.
with a 2 stage 150 + 150 i wold use 2 bottles, i have a 2 min drive to work, just for the track really. just wanted to know if that built bottom end could handle a 300 shot, bit its a 2 stage so a 150 off the line, then another 150 about 2 sec. out
ORIGINAL: mx07gt
ORIGINAL: MIAMISTANG2006
You said you could get nitrous @ $3 a lb right? Well you will have to run 15+lb bottles to be able to get some good passes. So to be optimistic you will fill them up once every week? thats 30 lbs. So thats $90 a week(360 a month). (not taking into consideration the gas you use going to place you fill them-up and if you dont buy the n2o at the track where it will surely be somewhat more expensive)
So you sure in the long run $360 a month you wouldn't be better just buying a blower or turbo set-up? The one thing I will give n2o is that it gives the best powerband of any power adder...
andrew
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
