92 on 93 tune?
92 on 93 tune?
A friend of mine didn't realize that wawa only had 92 octane gas and filled up the car. I have an 05 GT with C&Lintake/AR LT headers/axle back and evo 93 tune. Will it cause any permanent damage to run this tank? I have noticed a slight throttle lag with the 92. What do you think is best to do? thanks
RE: 92 on 93 tune?
If you have a Tuner and the user adjustable options are not locked out remove 1 degree of timing at full throttle.
If not dont worry about it. PCM will pull timing if you hit the knock sensor.
RE: 92 on 93 tune?
IF you don't have a tuner to adjust the timing (as Gene K suggested) or to reload a lower octane tune, then be easy on the throttle until you get to about 1/2 tank. Then fill with 93. This will get you roughly to 92.5. Stay easy on it and you should be fine to the next fill.
RE: 92 on 93 tune?
Yep, just don't lay into for that tank and you should be fine. I actually run a 91 octane tune for this very reason. I'd never notice the difference between the 91 and 93 tune, and the 91 version gives me a little flexibility for running anywhere from 91-93, etc...
RE: 92 on 93 tune?
ORIGINAL: Gene K
