slp loudmouth install?
hey guys a week ago i purchased a 2008 gt/cs and my slp loudmouths came and im just wondering if they are hard to install...i will have a stock midpipe and headers for now i was just wondering if its gonna be difficult or not to install?
RE: slp loudmouth install?
Axle-backs are quite simple to install. The only issues you may have is getting both muffs aligned just right which would require loosening the clamps on the mid pipes and twisting them a bit. But you may not have to do that at all; I didn't.
Slps are the easiest axle-back to install. the 2 piece design lets you adjust very easy. make sure you have a 13mm socket and box wrench and various size extensions to get at the hangers( factory muffs dont leave you alot of room to get to them) the slps go on so easy after that! shouldonly take you1/2 hr 45 mins tops
I put both of mine on within forty minutes. The the PIA part was getting them lined up perfectly. After about 5 weeks the one on the driver side shifted a bit....so I had to realign it.
very simple. if you a mechanic with a lift you're looking at like 5 min. once you get the car in the air. you're life is changed indefinately when you crank your car for the first time after the install...
[sm=drooldude.gif]
[sm=drooldude.gif]
Galactic
04-29-2019 02:56 PM
09-10-2015 08:39 PM
